DIY GT3RS front springs swap
Does anyone have instructions on how to swap the front springs on a RS without removing the strut? I’ve heard a spring change can be completed through the top strut hole.
I'm swapping to swift springs.
thank you
thank you
Is this to do quick setup changes at the track to find a track specific solution? Not much work to just pull the wheels off and remove the strut to do this on a workbench.
I guess you would jack up the car to droop the wheels, then remove (3) strut mount bolts and the strut top nut. Slide the strut mount out from the wheel well and pull the springs through strut tower opening.
There’s a youtube video out there. You need enough clearance to get the top mount off. I installed BBI kit this way.
https://youtu.be/1b6PdSkcAP4
