Did some DIY maintenance and have some questions….
Hey everyone,
I’ve done 4 track days in my GT3 and decided to do some maintenance/mods at the same time.
I did an oil change/brake flush and swapped out my PCCB rotors over to some AP Racing J Hooks with Ferodo DS 1.11 pads. Also swapped in the Tarett caliper studs since I’ll be doing a lot of DIY.
I don’t know what the alignment/camber settings are so I was wondering how many shims f/r a stock GT3 comes with? Getting under the car it looks like a 4mm shim on the front and rear of the car but I don’t know if it comes that way from the factory. I’m planning to get a track alignment but would like to know if I’m already working with some negative camber.
Also, the brake sensors on the rear went back in no problem but I had a lot of trouble with the front pads, the opening looks almost too small to fit all the way flush. Is this a common issue or are people tying off the sensors?
