No issue. Heat gun or preferably steam. Pull at a 45* angle with the panel instead of at a 90* angle to prevent as much adhesive from being left behind. There's a chance of pulling paint if the panel was repainted but probably less of an issue with a sticker compared to PPF which probably has a strong adhesive.
people saying take to shop... hah use a heat gun or your wife's hair dryer and a bit of patients and just peel off. they are not that old so should be easy to remove. if it does leave some sticky which 3m removed with heat usually does not you can pick up a can of liquidperformance RDX.
