Hello, I’ve looked everywhere online for painted harness pass through bezels for gt3rs lwbs. Found this picture online with them in Miami blue and have seen them in yellow on someone’s car. Anyone know where I can order them?
it is or was a factory option ... I personally have not seen an aftermarket solution since it probably requires the removal of the parts from the seat (which might not be possible)
They’re removable, 6 screws in the back of each, have done it before. Haven’t seen anything aftermarket either but would be great if someone, somewhere would make it so.
try bumperplugs.com they are well known to the RL community and will paint almost anything!
This was only available via CXX. You could also remove them and take to your local auto paint shop and have them sprayed Miami and put them back in. Will cost you around a hundred bucks or so as opposed to CXX which is around 1800 bucks if I remember correctly.
