Suncoast PDK Shift Boot Conversion
I liked the factory shifter much better than the aftermarket one, but the Suncoast shift boot is way nicer than the factory PDK plastic trim. Install was fairly straight forward. I did struggle a little with getting the bottom collar on the shifter to twist and unlock. I finally gave in and used channel locks with rubber to protect against scratches. Like another member here, my hazard assembly fell apart but I was able to put back together without issue. Overall, I am happy with the look. Much cleaner and more appropriate I think.
Was one of the first things I did - its relatively easy to do. I made a post about the process and which parts to order depending on what color stitching you want
Would you mind sharing the link to your post? I went through your thread history but didnt easily find it. Thanks!
