GT2 RS Aftermarket Exhaust Question
Nizer, I think this gives you a sense of the possibilities if you go with high-flow cats into a center muffler:
https://drive.google.com/file/d/1V1u...w?usp=drivesdk
The powertrain components are identical between our cars; I’d expect similar sound effects if you have a product with similar physics.
I also had a nice option which were the JCR hi-flo cats , these were 200 cell and changed only the cat section of the exhaust and made the exhaust louder with the valves closed and open . It retains the valves -& made the exhaust maybe 30% louder in both poistions . Was also a cool option and very high quality but i wanted more .
i have mine for sale , if interested pls pm me . Tks
Nice! How does it sound off throttle? As much noise as CRex's CS below?
Thanks. Lots of popping off throttle. Do you know what cell count cats Porsche use on the CS?
100 cell, per published specs. I am rather sensitive to nitrous oxides and don't sense much of it despite the low cell count.
The CS idea is basically two cats flowing into one big mixing chamber and straight out to the atmosphere. The big pops on throttle lift probably has to do with there being such a large void for vacuums to form and reverberate. Should be less of a problem if you have a commercial product with side exhausts. Would definitely recommend the 100-cell HJS cats in any case.
usrodeo4 (08-31-2021)
Basic Sponsor
Here is a dyno graph of the same car/same tune with Cat Bypass Vs. HFCs.
They are virtually the same. IMO 200cel cats are the best choice so that you avoid the CEL and do not have to worry about emissions while having 95% the flow of a catless set up.
Not entirely true.
Exactly, but I think you are misrepresenting the causal outcomes. With a tune optimized for cats it should/could out perform a catless car, but for a tune optimized for more flow (read decatted) it should certainly out perform a catted car, especially in a turbo environment. If it doesn't we need to revisit the laws of thermodynamics.
That's why we see ALL race cars with cats, right? Right???
Basic Sponsor
If you are running track only, go bypass pipes. If you are going to be primarily on the street, the cons far outweigh the pros.
