Goodyear Eagle F1 SuperSport RS Review
Recently I had the chance to get a set of Goodyear Eagle F1 SuperSport RS’ on my 991.2 GT3 RS WP and put them to the test around the Donington Park Circuit. After roughly 5,000 track miles on Michelin’s rival CUP 2R, with the odd day on the CUP 2, I was definitely curious to see how the Goodyear’s would hold up over some hard laps.
Conditions: Track temperature was typical for UK summertime, outside temp around 20ºC and partially cloudy with no rain.
First visual impression of the tyre was that it definitely shares some resemblance in tread pattern to the CUP 2R, mainly within the ratio of tyre to tread. However, the SuperSport RS definitely has a flatter and softer sidewall.
Out on the track... once up to temperature, the surface grip was good, and handling was pointy and precise on initial turn in. Mid corner & under braking is where I definitely experienced that softer side wall. The tyre felt hyper compliant to the track, which aided the grip, however a lot of the movement translated through the wheel, often giving the sensation the tyre was rolling over on itself.
Similar story under braking, a lot of movement at the front end, tyre felt nervous, but the grip was there. However, I did find that any small amount lock through the wheels when braking would unsettle the car.
Two laps in and the tyres were up to peak temp with 2.2 bar of pressure, but I did find myself needing to bleed the tyres down after each session (5-6 laps). I put this down to increased movement through the sidewall generating extra heat.
Tyre wear over the morning was great, even over all 4 corners and consistent across the tread. Obviously, a tyre of this nature doesn’t last long, but wear was nothing excessive. They peaked around 3 push laps in, followed by a steady decline. Hard to guestimate longevity as I only tested them for a morning, but they definitely had a full day left in them.
Final thoughts:
- If I had to judge this tyre against previous experience I would sandwich it between Michelin’s CUP2 and their CUP2 R, but obviously this is subjective to the driver and driving style.
- As a track day tyre the SuperSport RS is a great choice for some, plenty of grip and consistent between laps.
- Fundamentally a very different feeling tyre to the CUP2 R, more grip but a lot softer with increased movement and play under load. For me this feeling was quite unsettling, however as with any tyre setup the more time spent on the tyre, the more comfortable it’ll feel.
Final thoughts:
TDT (08-23-2021)
JonathanWalker (08-23-2021)
OP: Great info. Thank you.
Final thoughts:
