I was able to purchase a OEM Extinguisher with Brackets and bolts etc. Looking under the Pax seat I see a few possible mounting locations.
Can someone snap a few photos and post them where the bracket mounts.
You will need to remove the seat cover and make holes through the liner to access the hole in the to place the nut and bolt. One of the holes is already there. I believe it’s the one with the ground wire attached. You just need to loosen it and remove the bolt and then you’ll see where all the other mounts for the bracket will line up. I’ll try to get some pics for you.
