Porsche 991.2 GT3 RS w/ BBi Roll Bar Safety Package Installed at Racewerkz
Basic Sponsor
Attachment 1335528
Featured Dealer Install ➡️Our friends over at Racewerkz Engineering got this Porsche 991.2 GT2 RS ready for the track with our BBi Autosport StreetCup Roll Bar and Schroth Racing Harnesses Safety Package installed to provide additional protection and proper restraint.
The BBi Street Cup harness bar features a 2 piece design and high strength seamless tubing (1.75” x 0.095, 1.5” x 0.083) for excellent strength to weight ratio. With our sensible design approach, the 2 piece design mounts to frame structure, utilizing factory bolts, to provide strongest mounting points and maximum protection. For superior strength and rigidity, the bar utilizes “X” braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut.
Now in Stock Ready to Be Coated in Any Color, BBi Autosport 991 GT2 RS / GT3 RS StreetCup Roll Bars are available worldwide through our growing dealer network in North America, South America, Europe, Middle East, Africa, Asia and Pacific. New dealers & wholesale inquiries welcomed. Please email sales@bbiautosport.com for more information or click here to order ➡️ https://bit.ly/2GHUYpT
BBi Porsche 991 GT3/ GT3RS / GT2 RS Harness Bar with Optional Gussets
Attachment 1337417
Attachment 1337418
Attachment 1337419
Attachment 1337420
Attachment 1337421
Attachment 1337422
Attachment 1337423
Attachment 1337424
Attachment 1337425
Attachment 1337426
Attachment 1337427
Attachment 1337428
Attachment 1337429
Attachment 1337430
Product Link ➡️https://www.bbiautosport.com/product...etcup-roll-bar
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
When equipped with optional Sport Bucket seats, this bracket is required to install 6-point race harnesses. This bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
Features
Product Link ➡️https://www.bbiautosport.com/product...b-belt-bracket
BBi Harness Install Kit
BBi Harness Install Kit included extended bolts to properly accommodate both the OEM seat belts and racing harnesses at the factory mounting locations on the 991 GT3 / 981 GT4 Sport Bucket Seats. This kit features metal sleeves fitted around the bolts so that the belt brackets can pivot freely on the bolt. Sold as a kit per seat.
Product Link ➡️https://www.bbiautosport.com/product...at-991-981-gt3
Schroth Porsche GT3 Profi 6 Point Camlock Racing Harness 2X2 HANS
Attachment 1336540
Porsche GT3 Cup Cars come with Schroth belts direct from the factory. If you need to replace them because of an accident, or if you're putting the factory GT3 seat setup into another car, you'll want these belts.They are specific because of the lap belt attachment. They have a sewn-in bracket that fits perfectly on the factory mount. The Porsche GT3 Profi 2x2 features Frontal Head Restraint (FHR) specific 2” shoulder belts, 2" sewn GT3 laps, and a adjustable T-bar sub strap. The FHR specific shoulder belts are designed to make FHR use safer and more comfortable. The full 2" shoulder webbing fits perfectly on a FHR device, creating optimal force distribution on the surface of the device.
Product Link ➡️https://www.bbiautosport.com/product...ness-2x2h-hans
About Racewerkz Engineering
Attachment 1340120
1205 SOUTH FLOWER STREET
BURBANK, CA, 91502, U
(818) 802-7327
SUPPORT@RACEWERKZ.COM
- jerry@bbiautosport.com
Attachment 1337417
- 1.75” x 0.095”, 1.5” x 0.083” high strength seamless tubing utilized for excellent strength to weight ratio
- TIG welded and utilizes “X” braces on front and rear sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seat belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
Attachment 1337418
Attachment 1337419
Attachment 1337420
Attachment 1337421
Attachment 1337422
Attachment 1337423
Attachment 1337424
Attachment 1337425
Attachment 1337426
Attachment 1337427
Attachment 1337428
Attachment 1337429
Attachment 1337430
Features
- Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
- Precision CNC laser cut and bent from one piece high carbon steel for superior strength
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- Attaches to seat assembly using factory mounting points with all hardware included
- Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
- Made in the USA
Attachment 1336540
Attachment 1340120
(818) 802-7327
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
