991.1 GT3 Coolant Leaks
From: Mid-Atlantic (on land, not in the middle of the ocean)
My 991.1 GT3 recently had a coolant leak on track after the engine was replaced and broken in for 1200 miles. Apparently, a metal coolant line failed. The dealer claims that the failure was unrelated to the engine installation. Has anyone else ever had a coolant line failure or other cause of coolant leak on a 991.1 GT3? I've never heard of it here on RL.
if i remember correctly there is a coolant line to and from the engine compartment to the front radiator that is disconnected to drop the engine. did they share pics of the failed line? did the line rupture or did the connection fail?
I had a problem with a line failure after an engine change on one of my GT3's, it happened a few months after the change. It was on the to side of engine, at first the dealer blamed it on the engine swap but later said they did not know what cause the problem, the line was pinched, they replaced it no problem since.
