Mileage of 991.1 GT3 engine failures?
#256
#257
Is there any relatively accurate data out there of what percentage of F motors have had issues / been replaced ?
Is it a very high number ... 20 / 30 / 50 % ? Or is it more like 5% or less ?
Love my .1 and have had a trouble free ownership experience and was planning on it being a forever car.
However prudence suggests that I need to take a deeper look at the odds of a future issue ......
Thanks for any insights
Dundon bought an F Engine with 51k recently.
IslandBoy (09-07-2024)
#258
Hard to have exact data, and of course the internet represents most of the negative stories.
https://www.instagram.com/p/C7mzYtdS...RlODBiNWFlZA==
#261
slipaway37 (09-09-2024)
#263
Agree but the 991.2 GT3 Engine is highly unlikely of having any issues if taken good care of in maintenance and its a very small percentage of failures.
#264
Eventually all internal combustion engines will developed some type of issue. There is no lifetime internal combustion engine. I am afraid to post that it’s not if, it’s when.
Indyxc (09-08-2024)
#265
The same statement can be made about the 991.1 G6 engine. It's been around for 7 years now and failures are uncommon, unlike the earlier engines which were failure prone even 1-2 years into their lifecycle. The small number that have been reported appear to be one-offs that are not repeated problems (for example, one was a random bottom end failure)
#267
I can confirm from a lot of data gathering, no G6 or G0 V2 (DLC Cam G0) failures documented. We have found 1 G0 GT3 failure, and 2 G0 GT3 RS (without DLC cam) failures. Unfortunately on both GT3 RS, neither shared mileage. One was a vague story and not 100% clear if FF issue, the second was definitely a finger follower.
#268
Your statement is true but not when your $150K GT3's engine blows up around 20,000 miles only.
#270
Both engines (3.8, 4.0 and 4.0 2nd Gen) are based on the 9A1 block. The 1st Gen 4.0 was used in the 991 GT3 R and ran the 24h races. They changed some things with the 2nd Gen 4.0 but its not a different base engine
GT3 R engines are already different from all the street engines (camshafts, intake and some more) and the RSR ones are - still derived from the same base engine - another story again.
NNayak (09-19-2024)
