Some of you may know I’m new to the community with a 991.2 GT3 manual. Car has 2000 miles on it. I had vacuum line that came loose on the exhaust valve, fixed that. I had smoke on start up that has now quit and now a discovered oil leak. I pulled the bottom pan to install a Fabspeed center muffler delete and it’s soaked in oil. The leak is coming from up inside on the front (rear) on the engine. The belt is soaked in oil as well as accessory pulleys. Looks like I’ll hold off on the exhaust install and take it in for service. Is there a common area for leaks on this engine? I read where the oil tank can leak at the seam but mine is dry.
