WP Pro 991 GT3 Rotors IN STOCK at discounted pricing.
Former Vendor
Hello everyone! We have a couple sets of WP PRO front rotors for the 991 GT3 in stock that we are letting go for special pricing. These are brand new 2pc rotors that will fit 991 GT3 and 991TT centerlock cars with GT3 padsThe WP Pro front brake rotor kit can greatly improve your stopping performance on the Porsche 911 GT3. Upgrading your brake rotors will help provide better heat dissipation, allow for even wear of brake pads, and give you longer life out of your brakes overall. The 2 piece design saves rotational weight giving you better acceleration and even faster stopping. Whether being used for the street or track, upgrading your brake rotors from the standard rotors is a modification you do not want to skip!
One of the biggest advantages of 2 piece brake rotors is the rotational weight savings. Rotational weight savings has 3 times the affect over dead weight. So if you save 4lbs in rotational weight, that is like saving 12lbs of weight off each corner! Before the weight can be saved, WP Pro brake rotors go through an extensive manufacturing process. Rotors are heat treated up to 800°C (1472°F), to ensure the rotors can take the punishment from performance driving. Instead of large production runs like some manufactures, WP Pro treats each set of newborn rotors with a bespoke approach to dial them in by hand. Each rotor gets machined, assembled, and balanced to meet high quality standards.
The WP Pro rotors feature a unique Sun Cut pattern with the drilled holes overlaying the slotted design. This design saves more weight compared to standard round discs and improves the longevity of the rotor from it's cooling capabilities. With more effective curved vanes in a V shape, these further help dissipate heat away from the rotors. This design improves cooling by pushing cool air from the center of the wheel to where the rotor needs it most. The rotors feature a CNC machined aluminum hat that secures the disc to the rotor with a hardware that gives a true floating design. The hard anodized brake hat is extremely durable to not wear and scratch like standard anodized or powdercoated finishes. With the floating hardware design, this makes on the brake rotor the consumable item so you never have to replace the brake hat. Each kit is sold as a complete axle set up to work with the factory or aftermarket brake pads and stock caliper.
Includes:
Includes:
- Pair of 2-Piece Drilled and Slotted Rotors assembled with hardware and aluminum hats
- Stock Rotor - 11.20KG
- WP Pro Rotor - 9.55KG
- Hard anodized rotor hats
- Full floating assemblies with stainless steel M8 bolts vs standard M6 hardware
- Directional vented, heat treated, and coated rotors
Wow those are pretty.
That’s gonna be a no from me dawg
