Over Rev Help
#31
Obviously PDK - will prevent the money shift and range 3-6. So generally PDK cars are "safe".
I think the consensus is to not worry about over revs in range 1&2.
I remember seeing reports for 997 GT2's and they had tons of 1's 2's and 3's and people said those were fine.
cox1974 (06-30-2020)
#33
Mine hit the rev limiter one time on a 2-3 shift and it showed 9177.5 RPM max engine speed, 99 stage 1's and 8 stage 2's, total duration at overspeed 0.00 S...
You're good!
#34
Thanks! Now I need to research value... and make a deal. ;-)
#35
Received 5,413 Likes
#37
Good luck. They seem to be trading quickly these past few months. Around sticker and some even above - depending on build. Do some searching here. Some recent threads should help...
Here's one: https://rennlist.com/forums/991-gt3-...s-touring.html
#38
Was "wired" Apple CarPlay a named option for 2019? Or included... for 2020 I think it needs to say SIRI enabled, but believe that means Wireless Apple CarPlay
#39
Included in my GT3T. Wired only - which I like because it keeps the phone charged. The integration is really nice.
The only options I purchased for the entertainment were "Voice control" (which was $0) and the Bose system. I don't think those make a difference for CarPlay though...
#40
That's interesting that they show the clutch position in percentage. Does that mean it's used a little over 10% of its clutch disc thickness?
