991 GT3, GT3RS, GT2RS and 911R 2012-2019
Replacement 991.1 Engine Question
Old 08-06-2020, 07:27 PM
991carreradriver
991carreradriver's Avatar
I have never had smoke on startup or low acceleration on a "G" engine. This is not normal.
Old 08-06-2020, 11:28 PM
Jickel180
Jickel180's Avatar
Had smoke on startup with my F motor, but never on my G motor yet. It’s normal from what I understand on cars that are babied and/or shut off abruptly without idling for a few secs.
Old 08-06-2020, 11:32 PM
911TurboRules
911TurboRules's Avatar
I was at the dealership today and showed them the video and they said it's normal as long as it stops and doesn't keep on producing smoke.
I'll try to let it idle for a few seconds before shutting down to see if that makes a difference. My car is not babied (4 track days already this year) but I don't think abused either as I do the required maintenance with minimal annual oil change and brake flushes.
Old 08-07-2020, 06:56 AM
Cay_PI
Cay_PI's Avatar
Don't care... some smoke, some not. Depends on how the piston rings settled during break in and also how the car is shut down and parked. Mine never smoked but I wouldn't care.
Old 08-07-2020, 01:35 PM
majedameeri
majedameeri's Avatar
I haven't see any smoke in my replaced .1 GT3 engine even on startup. Prior to the engine replacement it used to smoke up only on startup.
Old 08-07-2020, 01:41 PM
rsbenfield
rsbenfield's Avatar
Same for me, no smoke with replaced G motor...only on startup with old F motor.
Old 08-07-2020, 02:59 PM
ksozay
ksozay's Avatar
+1 - Smoke on original E engine. If I let idle for a few moments before turning off, it wouldn't smoke.
No smoke on G engine.
Old 08-07-2020, 07:51 PM
911TurboRules
Will the smoking be considered enough reason for the motor switch to the "G" motor? Did you guys with the G motors have any other issues in order to be eligible for the G motor swap?
Old 08-08-2020, 10:56 AM
ddugas01
ddugas01's Avatar
I’ve got a ‘14 as well. I started seeing white smoke @ startup when the thermostat started to fail. Once replaced, no more smoke.
Old 08-08-2020, 11:01 AM
911TurboRules
Interesting. How did you know your thermostat was failing?
Old 08-08-2020, 12:23 PM
usrodeo4
usrodeo4's Avatar
Originally Posted by 911TurboRules
I have a late 2014 that got the motor replaced before delivery in 2014 but not a "G" motor. It smokes up maybe 1 in 5-6 starts. Here's a video. Anyone else with similar issues?
https://youtu.be/qVL7fGHQyIQ
Paul
That is white smoke, indicating oil...I am not up to speed on the 911 engines yet but in the old days with American V8's I would say the valve seats may be leaking or the intake system is experiencing some oil blow by back into the intake system some how.
Old 08-08-2020, 04:35 PM
911TurboRules
Service person said if the valve seats are leaking it would be on going smoke even while you drive. Mine just poofs smoke at startup and then drives fine. No lights or other issues.
Old 08-09-2020, 08:29 AM
Cay_PI
Cay_PI's Avatar
Its nothing to worry... the piston rings are designed that way. They made them mor tight with later engines to reduce oil consumption. But the smokers may run with less friction and have a bit more power.
Old 08-10-2020, 01:04 PM
rsbenfield
rsbenfield's Avatar
I don't think occasional smoke at startup would constitute a replacement unless its smoking non-stop while running.
To your second question...no other issues other than engine faults at high RPMs.
Old 08-10-2020, 02:34 PM
KOAN
KOAN's Avatar
A little smoke at start up, especially after a long rest, is quite common. The criteria for a new motor are very specific, including CEL showing abnormal detonation, and inspection which shows abnormal rocker arm wear.
ksozay (08-12-2020)
Quick Reply: Replacement 991.1 Engine Question
