Upgrade $8k DUNDON 93mm plenum throttle body and air filter box?
I previously did the following DUNDON Exhaust modification on my manual 2018 GT3 (which I love ~12k):
-991.2 GT3 Long Tube Street Header Exhaust System, 991GT3-RS-LT-Catted Full System
-GT3 Lifetime Center Muffler, Black (Loud) 991
I am now considering upgrading to a 93mm plenum throttle body and air filter box.
Per DUNDON...
“Help your 991.2 GT3 BREATHE!!!
We found in our exhaust development and testing of the 991.2 GT3 and RS that they are intake limited both through the factory airfilter box and throught the 82mm Throttle body. A bit of history. The Bosch 82mm Throttle body is the largest Bosch makes and was used as far back as the 996 GT3 which made 380hp. The Air filter box used on the 991.2 GT3 and the 991.2 GT3RS originally showed up on the 2013 991 Carrera S which makes 350hp. Your 991.2 GT3 is rated at 500hp, so you can see just from these numbers that the intake side of things is a constriction.
In our testing we found the the stock airbox to be about a 0.2-0.3psi pressure loss and the 82mm throttle body to be about 0.3-0.4psi of pressure loss. Naturally aspirated engines make power from the force of the atmosphere pushing air into the engine, so every 0.1 psi helps! Our combo of 93mm Throttle Body and Dual Cone Airbox reduces the losses to under 0.1psi.
Dual Cone Airbox for 991.2 GT3
Stock Filter Area :1.77 ft2
Reverse Dual Cone Filter Area: 4.96 ft2
280% more than stock.
More filter area means slower air speeds through the filters and less pressure drop across the filter element
93mm Throttle Body has 28.6% more area than the 82mm throttle body.”
It’s my understanding that this upgrade improves the performance in the upper revs. Is this worth the $8k+ cost? Opinions? Has anyone done this?
Per DUNDON...
The following 2 users liked this post by twospyders:
porscheflat6 (10-18-2020),
s4corrado996tt (10-19-2020)
![](https://rennlist.com/forums/images/buttons/collapse_tcat.gif)
Popular Reply
10-23-2020, 02:33 AM
Basic Sponsor
Simple answer, don’t buy it if you don’t see the value in it.
Is it expensive to build a quality low volume part to best a billion dollar companies capabilities, yup. But we did.
Is it expensive to make all of our parts in the USA (I caught the innuendo that we don’t). But we do.
Have we sold thousands of these kits like all the GM BMW Honda and Subaru tuners expect to, nope was never the plan. It’s a niche of a niche and we’re ok with that.
If it’s so easy and possible to do, why is there no one else offering a competitive product?
Seems typical Rennlist drama lovers are back and have nothing positive to say and choose instead to try to tear down what hard working US entrepreneurs are offering even after multiple others have illustrated eloquently that the parts work, and they were happy.
We’re busy helping customers that see value in what we provide, if you don’t, again, don’t buy it....
For those that asked for a group buy the code is still open and is more discount on this kit than we’ve offered.
Lots of guys running them and I’ve seen only positive reviews. Impressive dyno results per Dundon. I bought street headers, airbox, plenum, throttle body when they first came out. Parts are still in my garage I need to find some time to install soon. Will report back.
The following 2 users liked this post by Johnny Five:
twospyders (02-15-2020)
Good question. My impression has been that of the two options, installing the Dundon headers provides the most bang for the buck because while you’re dropping 40lbs from the car removing the side mufflers, you’re also adding a lot of low end torque (which the car particularly needs), and a modest amount of high end torque (average of about 6-8lbs in higher range, basically .2 RS torque in higher ranges.
Adding a few additional ft lbs more torque in higher ranges with the airbox/plenum sounds nice, but 8K is a lot of money for that.
Would nice to hear from someone who tried both products back to back?
Headers alone, and then headers + airbox/plenum.
The following 3 users liked this post by Drifting:
![order](https://rennlist.com/forums/graemlins/order.gif)
On a side note: I've been looking at the GMG Headers.. Has anyone compared them with the Dundon ones?
The following 3 users liked this post by AllAboutThatP:
The following 4 users liked this post by Johnny Five:
I did the whole Dundon deal with full exhaust (loud muffler), plenum and airbox. Been running it for 2-3 months. Love it and would do it again. Changed the car. It is very noticable. YOLO.
The following 4 users liked this post by joejenie:
I have Dundon race headers on my 991.1 GT3RS. Fully transformed the car. Hands down the best money I've ever spent.
Power. Noise. What more can you ask for?
I'd like to know the results of just doing the intake/plenum/throttle body, but with stock exhaust.
The following 2 users liked this post by FourT6and2:
Jamie@dundonmotorsports (02-18-2020),
Basic Sponsor
That said we do still see sub atmospheric pressure in the plenum with the stock exhaust and stock TB.
Dundon Motorsports
Gig Harbor, WA
253-200-4454
jamie@dundonmotorsports.com
www.dundonmotorsports.com
Facebook.com/dundonmotorsports
Instagram @dundon_motorsports
Dundon Motorsports
Gig Harbor, WA
253-200-4454
FourT6and2 (02-18-2020)
I am considering buying this Airbox.
I already have full Akrapovic Titanium system (headers, high flow cats, side deletes & muffler box)
Seen as though my current system isnt DUNON could i still expect similar results?
And do Dundon ever do "sales" % off.
