GT3 RS WHITE with AURUM GOLD rims in Los Angeles
gold FTW. also what are the yellow on the leading edge of your wing? going for the GT3RS dodge charger look?
Maybe you can Browse my photo Album..
There are a lot of graphics mods on the car with yellow accent and white strip on hood.
But when i go gold.. i will need to reassess maybe.. ? !
The bottom pic has the old stripes that were slightly wider
The middle pic shows the new strips.. slightly narrower and pointier.
Finally done..
powder coated the black rims to Gold (Prismatic Satin Poly Gold.... no clear coat)
To me it has completely transformed the car.. it is Gorgeous... could not be happier.
Cheers all for your comments and input!
yojimbo007 (09-13-2019)
Its not paint.. its rubber stickers.
There is this place in VanNuy (Los Angeles ) California called ‘Tire Stickers’ https://www.tirestickers.com/
They specialize in tire lettering.. they can pretty much make anything.
In my case they scanned the tires lettering and transferred to their computer.....had their plotter cut out the lettering and then they glued them on.
The whole process was about 2 hours.
Its about $270ish, if i remember correctly, if u want them to install.. ......if not its about $150ish for 4 tires.. u glue them yourself.
Very good product..
They also have transfer stickers for less.... but those don't last as long....
The rubber sticker will last as long as the tire....
Check on line.. u can also mail order.
Very good product..
Her twin sister today...
I think it is mostly the effect of the yellow wing tips that does not work with the gold wheels.. ..
But i still like the hood strips and the yellow accent on the side.
I will probably remove the yellow on the wing and .......?? Need to do some experimentation .. to keep it coherent...
Will post pics once i make the changes.
Thanks for the input 👍👊👊
yojimbo007 (09-14-2019)
HushyPushy.
GORGEOUS!
GORGEOUS!
