GT2 RS boost being limited
Went out for a spirited drive yesterday morning, and at some point the car started feeling a little sluggish. I noticed that the boost was climbing slower than usual, and maxed out at around 10-11psi instead of the usual 16-19 (depending on gear). I've had this happen once before, and it was gone next time I drove it. So this time I decided to pull over, shut off the car, and then start it back up. That solved it, boost was back to climbing quickly, and maxing out where it should.
Anyone else seen this? No messages were logged, car didn't complain about anything.
Basic Sponsor
Most common cause would be a de-rate due to excessive IAT's. Did you have water in the tank?
JC
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
Yes, losing 6-8psi of boost means much more than 50hp difference...
Does the car actually let you know when the distilled water needs to be refilled?
Basic Sponsor
JC
Huh, I'll take a look, I think I saw somewhere else that it throws a message when it's time to add water. I might be wrong...
In any case, don't think that's it, as it felt almost limpy in how it built pressure. Given the fairly low temperature, seems unlikely. I do drive at 6500-7100' of altitude, so maybe...
Oh yes, same here, I'm running 91 octane in it. Good point. If there's plenty of water in the tank, I'll have to try mixing in some higher octane race gas.
