Harness/Sub belt question
So my dealer didn't properly move my harness setup over from my 991.1 RS to my 991.2 RS.
Quick question for all, I have the Schroth Harness and I had the BBi sub belt mount. Is it possible to install the sub belt mount bracket first reinstall the chair then do the wrapping for the sub belts?
I reordered some missing parts for delivery yesterday because I was missing the sliders on the sub belts to complete the wrapping but they never showed up and my appointment is this morning to install the bracket so I'm trying to figure out if I can install the bracket then install the sub belts monday
Also does anyone have a video guide or illustration as to where the side anchor points are in the car?
Thanks!
Thanks!
I have BBi harness bar and had to remove and rewrap my Scroth harness after seat was installed. It wasn’t very difficult. Just pull out seat cushion and you should be able to get it around sub frame. Just took a few minutes.
Going to be buying a sub belt mount. I've read Cantrell is supposed to be great. Any difference with BBi?
BBi has worked perfectly for over a year and 25 track events. Not sure about Cantrell but likely works well. The GT3 Schroth belts allow for full use of regular seat belts for street.
Given the price point being similar I'd opt for the Cantrell only because the wrapping is easier.
Can't go wrong with either really.
https://www.schrothracing.com/produc...e-harnessbelts
Also, do the sub belts need wrapping? Looks like there is a bracket at the end of the strap.
Yes the sub belts are wrapped around the mount under the seat. You need to adjust the length of the sub belt so the camlock is at the correct position (you will need to see Schroth recommendations for this positioning).
I'm not sure exact name but it was the GT3 specific 2inch Hans belt that allows me to easily use the regular seat belts.
