Voodoo Porsche 991 GT3 RS with Color Matched BBi Roll Bar Installed
Basic Sponsor
Attachment 1344394
We just wanted to share this beautiful Voodoo Blue Porsche 911 GT3 RS that has our BBi StreetCup Harness Bar installed. The bar was powdercoated in Voodoo match the exterior, and here are some pictures that we would like to share below!!!
Vehicle Specifications
BBi Porsche 991 GT3/ GT2 RS Harness Bar
The BBi Autosport Bar features a 2 piece design and high strength seamless tubing (1.75” x 0.095, 1.5” x 0.083) for excellent strength to weight ratio. With our sensible design approach, the 2 piece design mounts to frame structure, utilizing factory bolts, to provide strongest mounting points and maximum protection. For superior strength and rigidity, the bar utilizes “X” braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut.
Features
- jerry@bbiautosport.com
- BBi StreetCup Roll Bar Custom Voodoo Blue Finish
Features
- 1.75” x 0.095”, 1.5” x 0.083” high strength seamless tubing (DOM) utilized for excellent strength to weight ratio
- TIG welded and utilizes “X” braces on front and rear sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seat belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
