991 911R Electric Parking Brake Won't Release
This is kind of hilarious, and unbelievably frustrating situation.
Parked 911R at dinner last night. Get in to leave, parking brake won't release. I normally pull it manually instead of using the "drive off" procedure, when I pulled it this time the "brake" light on the tach and the "PARK" on the release handle flashing red, and on the dash it says "release parking brake."
No fault, no error message, just tells me to "release parking brake." I tried to pull the handle w/o my foot on the brake which then tells you "press brake" but changes nothing.
Doing the "intent to drive off" procedure, which is seat belt on, door closed, put the car in gear and release the clutch to drive off does nothing.
Power cycling and repeating various combinations of the above process does nothing.
Porsche service center by me is closed on weekends.
I've seen a bunch of threads, but most people with some combination of the above procedures are able to get the brake off. Playing with the stalks (lame attempt to acknowledge the message to release the brake, no joy).
I was hoping maybe a fuse to pull? The only fuse I can find is for the parking brake handle...which says nothing about the mechanism itself. Ended up taking a freaking uber/lyft home and the car is 30 minutes away (safe location) but less than ideal and really, really annoying.
I don't have a Durametric or PIWIS, apparently there's a re-calibration or something you can do on the brake (probably intended post brake job) alas, Porsche service center is closed on the weekends...
Would love any input or ideas from the hive mind..
I had that happen to me on my .1 3RS.
I was lucky enough that when I turned the car on and off and fidgeted with it a few times it magically released.
I was also lucky enough that it was a weekday and drove it straight to the dealer.
I told them not to turn the car off before putting it on a lift but they did, and so it got stuck in their drivethrough service area and they had to dolly it to a service bay.
Not sure if your is the same issue but in my case it turned out to be a fried actuator.
I hope it's not in your case cause I don't even know how you'd get it on a flatbed.
That sucks. But it's also kinda funny in a dark sort of way.
I never really use my parking brake, just keep the car in gear. Unless it's an abnormally steep hill or something.
Location: Québec, Quebekistan, Magic Kingdom of Trudeauland
By power cycling, do you mean getting out the car and locking it to arm the alarm, then reopening it ? This is how to reboot the electronics like restating windows on a computer.
GT3 player par excellence
Annand, just leave it where it is... did you say it was in the redlight district near chinatown?
and go buy a real porsche... you know like 997RS4.0 you been talking about. it has a REAL E brake
Tried, thanks ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Tried the Contra code essentially, no go on anything. We are gonna go back tomorrow with our tools, get the rear diffuser off and some proper dolly's to try to roll it away
Honestly all I can do is laugh now. Glad someone else found the humor in it ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Sadly, I've gone through a ton of BMW's, I'm all too familiar with this hilarious "code." Also disconnected battery etc.
lol you're the best
Me too.
Me too.
Huge thanks to mooty for reminding me that Chasen (SP Motorsports) is around and is AWESOME. Came out with a PIWIS and spent way too long trying every trick he could find. Some sensor or something is fried. We ended up popping the diffuser off, using some jacks, blocks, and hopes & prayers (car was parallel parked on a slight downhill) to get a tow bar under the rear, pull it off the curb, and then get it towed...what a weekend
Really, really shocked there is no hidden mechanical or electrical release for this thing.
^ glad you got it out of chinatown.
I heard CGT has manual handbrake.
I will have one delivered to your compound on Monday.
wire at your convenience.
I drive my car regularly. I'm so sorry. This is my worst nightmare. The E brake is the only thing I don't like about the R. Please keep us informed regarding the fix. Maybe there is some updated electronics we should be aware of. Thanks.
Dealership found right side actuator seized. Being replaced under warranty. Service manager & tech have never seen this fail before...
