Front trunk contents of 991.1 GT3 RS
I just received delivery of a 2016 GT3 RS as a CPO vehicle, and of course it drives very well!
However, upon delivery as a CPO vehicle from a dealership out of state, there was nothing in the front trunk (frunk) side holders.
What is standard for inclusion in these side molded plastic holders for a new 2016 GT3 RS?
(I assume that it's at least to contain the flat fix on the left side holder, and a tow hook, and center cap removal tool, as well as possibly the center lock removal tool on the right holder.)
Thanks!
Thanks!
Thanks redmonkey!
Unfortunately, I just checked under the batter lid, and found that the centerlock nut is absent from there also. There is no center cap removal tool in that small circular compartment either.
The pump/inflator is present in the box shaped compartment.
I do not see any sealant compartment. Where exactly would that be?
The CL nut and remover would be in the same circular compartment - you need to remove the circle cover. Typically the remover is in the nut itself (the center of it). If that compartment is empty, you need both parts.
Thanks tstafford!
Yes, the inside of the circular compartment is completely empty, so I'll ask the dealership to provide those items as part of the CPO.
Is there supposed to be a sealant also? If so, where exactly is that located under the lid?
Also, is there supposed to be a tow hook included?
Thanks!
Thanks!
Alright, so I reviewed the owner's manual, and found the following: the tire sealant is supposed to be in the left side molded plastic compartment. The right side molded plastic compartment is supposed to contain three items: a towing lug, a tool kit, and an emergency plastic wedge.
Under the lid in the center is the inflator, and just to the right of that is the circular compartment that is supposed to contain the center cap removal tool, and the center lock nut removal tool (?polygon tool).
