991 GT3, GT3RS, GT2RS and 911R 2012-2019
Black Porsche 991 GT3 RS Lizard Green BBi Roll Bar & Schroth Harness Install
Old 02-18-2019, 02:27 PM
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Default Black Porsche 991 GT3 RS Lizard Green BBi Roll Bar & Schroth Harness Install
Attachment 1344394
We recently took delivery this Black Porsche 991.2 GT2 RS to install our BBi StreetCup Harness Bar and Schroth Racing harnesses on both the driver and passenger sides to provide improved protection and proper restraint. The bar was powdercoated in Lizard Green to match the belts and wheels, and here are some pictures that we would like to share below. Stay tuned for updates!!!
Vehicle Specifications
  • BBi StreetCup Roll Bar Lizard Green
  • BBi Sub-Belt Bracket x2
  • Schroth Racing GT3 HANS Harnesses x2
BBi Porsche 991 GT3/ GT2 RS Harness Bar
The BBi Autosport Bar features a 2 piece design and high strength seamless tubing (1.75” x 0.095, 1.5” x 0.083) for excellent strength to weight ratio. With our sensible design approach, the 2 piece design mounts to frame structure, utilizing factory bolts, to provide strongest mounting points and maximum protection. For superior strength and rigidity, the bar utilizes “X” braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut.
Features
  • 1.75” x 0.095”, 1.5” x 0.083” high strength seamless tubing (DOM) utilized for excellent strength to weight ratio
  • TIG welded and utilizes “X” braces on front and rear sections for superior strength and rigidity
  • Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock seats or any aftermarket seats on the market
  • Allows full seat travel to accommodate taller drivers
  • Can be used with stock seat belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
  • Made in USA
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
When equipped with optional Sport Bucket seats, this bracket is required to install 6-point race harnesses. This bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
Features
  • Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
  • Precision CNC laser cut and bent from one piece high carbon steel for superior strength
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • Attaches to seat assembly using factory mounting points with all hardware included
  • Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
  • Made in the USA
Product Link: https://www.bbiautosport.com/product...gory=991%20GT3
Schroth Porsche GT3 Profi 6 Point Camlock Racing Harness 2X2 HANS
Porsche GT3 Cup Cars come with Schroth belts direct from the factory. If you need to replace them because of an accident, or if you're putting the factory GT3 seat setup into another car, you'll want these belts.They are specific because of the lap belt attachment. They have a sewn-in bracket that fits perfectly on the factory mount. The Porsche GT3 Profi 2x2 features Frontal Head Restraint (FHR) specific 2” shoulder belts, 2" sewn GT3 laps, and a adjustable T-bar sub strap. The FHR specific shoulder belts are designed to make FHR use safer and more comfortable. The full 2" shoulder webbing fits perfectly on a FHR device, creating optimal force distribution on the surface of the device.
- jerry@bbiautosport.com
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
BBiAutosport is offline
Old 02-18-2019, 07:45 PM
BBiAutosport
Basic Sponsor
Old 02-19-2019, 01:24 PM
BBiAutosport
Basic Sponsor
Quick Reply: Black Porsche 991 GT3 RS Lizard Green BBi Roll Bar & Schroth Harness Install
