Center locks again - torque wrench vs adapter
#32
#35
Here is my 2 cents. I use the Neiko digital gauge and their torque multiplier. Do not put the reaction bar on a 2x4. I rest it on a jack stand set up so the reaction bar is horizontal. This will direct all force straight down and NOT steer your front wheel. I also apply maximum breaker bar force with the bar horizontal. Less force trying to steer the wheel as well.
Williams has a reasonably priced 4:1 TQ multiplier that I have not tried yet. Central Tools also has a 4:1. They both look alike and prob are made by Central Tools.
catdog2 (05-02-2021)
alasorte (03-09-2020)
#38
The Renntorq tool is compact, elegant and minimizes the potential for damage when changing centerlocks.
Sure,you can cobble together the cheapest equipment possible and accomplish the same job, with a little more risk and inconvenience. To each their own!
Tumbleweed (02-14-2021)
#39
Originally Posted by e6tme
Ha! That's kinda the same argument a Corvette buyer might make to a Porsche owner.
911TurboRules (03-15-2020)
#40
Has anyone tried these other torque multipliers? Both products might be from the same manufacturer. Pictures shows "Made in the USA". They are 4:1 multipliers and have longer reaction bars than the Nieko. I'm wondering if the longer reaction bar would allow leveraging the bar against the ground, instead of needing a jackstand to prop it against. Or maybe the extended length becomes more of a hindrance and a threat to the fender if it slips? Certainly the 4:1 vs 3:1 multiplication factor would help a bit.
https://www.amazon.com/dp/B001DIG3EK/?coliid=I3L82XNHDE4U1W&colid=1H6XFTCE04G68&psc=1&ref_=lv_ov_lig_dp_it
#41
#42
I only use the digital torque adapter to calibrate the torque wrench. It makes it stick out to far from the wheel and you add another bad levering effect. Once in a while I use the digital torque adapter to recalibrate and check the torque settings but most of the time it's just the Neiko multiplier and the torque wrench. With the GT3 its tough with the front wheels not locking and rear steering to keep the wheels from turning left and right but try to keep the wheels pointing forward as much as possible to apply as much direct force as possible and make it less likely to slip. It's a PITA still. I think I'd rather have the 5 lugs.
#43
#44
The tools needed for the Neiko torque multiplier:
1) Neiko 03715B Torque multiplier
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2) Torque wrench that can go at least up to 150 ft-lbs. I use this eTork wrench. $90
3) Neiko 20743A Digital Torque Adapter. I didn't know this existed.
4) Center Lock nut (you should have in your car)
#45
The torque multipliers have a ½” drive input and a ¾” output, so you can use these with a standard ½” torque wrench.
I have a Central Tools 4:1 torque multiplier for sale. This is similar to the Neiko tool but provides a 4-to-1 ratio and is made in the USA. Will sell for $200 shipped. Here’s a link:
