JCR // Titanium Silenced Bolt-On Exhaust Tips (New Product plus Intro Offer!)
Hey all,
Time for another new product launch, another to follow next week!
We have included an introductory offer for the first 10 customers and parts are in stock and ready to ship right away.
To benefit from the RL intro offer please just PM requesting your code, this can then be input during the online order process and your price will be reduced.
If you have any questions at all please do not hesitate to ask!
JC
Introduction
Many 991 GT owners use their cars as intended on-track. The car from the factory is near perfect in its preperation as a road car suitable for high speed track work, apart from ocasionally in one particular area, noise.
The JCR Titanium Silenced Bolt-On Exhaust Tips are suitable for fitment to all 991 GT based cars and any centre exhaust section which utilises the factory 3-bolt flange arrangement and significantly cut exhaust volume. Perfect for either a preventative measure prior to a track day or as a quick fix to reduce levels if weather conditions change and the noise levels become marginal.
Continuing the theme of our modular exhaust products our silenced tips are a quick-to-fit part, ideal for swapping out during a day at the track if the noise levels become a little marginal on the day. 10 minutes and some simple tools are all thats required.
Factory 3-bolt flange retained for easy installation
No Compromise
The JCR Titanium Bolt-On Exhaust Tips are lighter than the OEM 991 GT3 / RS exhaust tips, this was a key goal during the design and manufacturing process to ensure that when installed there is no need to worry about extra loading on the factory / aftermarket silencer which is usually the case with heavy steel alternatives.
OEM 991.1 GT3 RS Tailpipe
Cuts Volume
Our high quality bespoke made titanium silencers will not only last but also are highly effective at reducing exhaust volume. In testing we saw a consistent reduction of 3-5dB depending on the circuit and weather conditions. Often during a track day the 991 GT cars can pass the static noise tests without too many issues however can be very marginal on the drive-by noise limits once at WOT with valves open. This product allows customers to make a quick change to avoid the track event ending early and losing out on entry fee's and enjoyment during the day.
High quality bespoke titanium silencers with internal detail to accept factory style exhaust flange tip
Here we have our Titanium Silenced Centre Bypass combined with our Titanium Silenced Bolt-On Exhaust Tips, a great combination for track drivers who want light weight, high performance and controllable sound levels.
agreed. seems like the ideal solution for those that run at tracks with a DB meter. props to JCR for the innovation and what looks like a great product. I would suggest a pic of them installed if you want to move some of these though (I'm sure buyers will want to see)
Of course, this particular part is our T321 stainless steel prototype installed on a 991.1 RS. You'll notice the production Titanium version features slightly more pronounced down turns on the tips for further sound suppression however the base flange and overall silencer dimensions remain unchanged at 150mmx100mm.
Keen to share as soon as our final production Titanium versions had been completed. I have images of our titanium test piece too which ill share tomorrow / as soon as I have access to the images, looks rather special all coloured up after heat cycling!
Originally Posted by porscheflat6
Wow that is great for track with Db restrictions
Very cost effective and simple solution to a pretty big issue that a lot of track enthusiast owners face
