DS1.11
Basic Sponsor
The backing plate thickness rule of thumb is a good one to follow. That is typically about 5mm. As others have mentioned, you need to watch them closely as they get thinner. They lose some thermal mass vs. when they are thicker and new, and they will burn more quickly the thinner they get. Also, make sure you always check the inner and outer pads in your calipers! The inners sometimes burn faster than the outers, so just peeking through your wheel spokes to asses the remaining life doesn't cut it! I've seen customers trash their discs when the steel backing plate digs into the the relatively soft iron disc ring.
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
![](https://rennlist.com/forums/signaturepics/sigpic110137_8.gif)
Jeff Ritter
704-824-6030
