Tidy full harnesses when not in use
Mine can't be adjusted while sitting either !
Hi Cobalt appreciated your answers and pics. A couple of questions..... How do you remove the Schroth buckle? I've seen comments about just pressing something on the rear? Also, I think the dealer has installed the anti sub straps incorrectly. There is no adjustment possible unless you move the seat forward and fiddle at the floor mounts. They cannot be adjusted whilst sitting? Sorry to pester!!!
The buckle is removed as per the other post above. I actually keep a small Allen wrench in my arm rest to remove the buckle-push it into the small hole at the back til you hear a click then pull. Just pop it back on when you need it.
