GT3 Rear Wheel Steer Fault
#31
Same issue here a few weeks after having some work done.
Had only driven about 3 short drives, and then had power steering fault pop up and go away a few times. Then one day driving straight down the highway had power steering fault come on followed by rear wheel steering fault a few miles later. No change after disconnecting battery for a week in the garage, and awful driving at slow speeds without power assist.
Dropped off for a day at dealership and they discovered a loose ground connection on a bolt somewhere in the rear as a result of the recent work performed. Tightened up and all good again.
#32
why are these cars SO sensitive to voltage issues that manifest as faults in systems like RWS, PADM, PASM etc ...
