sway bar adjustment
the GT3 .2 has three settings on the sway bars. From the factory it come with the middle setting. Has anybody gone to the max setting on their sway bars. If so, did you notice much of a body roll difference? I am considering doing this on mine since it does seem to have a bit of sway around corners.
Not to insult your intelligence, but did you turn on the Sport mode with the PASM button first? That stiffens the chassis considerably and would eliminate some of the roll if you haven't done that already. But to answer your question, I never considered moving both in the same direction. Seems like that just reduces grip at both ends without changing the handling dynamics. I'd only adjust the sway bar to tune the oversteer/understeer more to my liking by changing one and leaving the other as is. Or changing them both but in opposite directions. Just my .02, YMMV
I have set my rear bar to full stiff (front bar remains in middle) for moving balance towards oversteer. Haven't noticed a big difference yet, but haven't tracked it like this yet. Generally adjustable swaybars are there to adjust handling balance at the limit, rather than to prevent a bit of roll in corners.
I believe TPC-Racing are actively working on some off the shelf maps for the .2
This. The adjustment is to change oversteer/understeer balance, not about roll. Most street cars are set up to understeer, so it makes sense to dial in less understeer - more oversteer for better corner rotation. This will be my first GT3, though, so i will see how it behaves on the track with the factory settings. I sense I may do what Grant did, stiffen up the rear. In my prior track toy, a C4S, I softened up the front and stiffened the rear. Great car rotation around the corners, but that setting chewed up the front tires too much.
