GT2 RS on Dyno, does not make 700hp
Can’t read the blurry ending? 681rwhp??
Definitely sounds nothing like a GT3, but very fast!!
"First new GT2RS dyno. Our friend Ekanoo strapped it down and it made 683rwhp. That’s a lot more than 700hp to the crank
![](https://www.facebook.com/images/emoji.php/v9/f7b/1/16/1f44c.png)
Typical ballpark numbers from crank to wheel are a 15% loss meaning the GT2 RS crank is putting out 805hp.
Again, I don't know that 15% is Porsche's loss but in any case this is very impressive!
The text states:
�� Check it out."
Things haven't moved on much have they, people still thinking a 7 second spin up of a drum can accurately measure the flywheel manufacturer stated full load hp of a turbo car - it can't you need an engine dyno for that and the engine needs to be braked at peak power with the appropriate cooling until a stable torque output is measured - it will be 705NM (which translates to 700PS) as stated and declared for EU homolgation - the more moot question is whether the motor can hold its 700PS on the track without the water sprayer, early indications are that it can't.
Dynos aren't good for measuring BHP. Just deltas for before/after. It blows my mind people still think you can throw a car on a dyno and calculate accurate power/torque at the flywheel/crank. Doesn't work that way.
Yes, I think the formula for determining flywheel hp from a chassis dyno is much more complex than a simple percentage. I think it is non-linear...
