Curb alert
Actually I was referring to a device called curb alert. It detects by sound wave your distance from a curb and beeps in the car as you approach the distance you define. Totally prevents touching a curb when pulling into a parking spot.
them work like a charm. After you calibrate it it will warm you with beeps whenever you get too close to curb.
I just got a Cayman S and about to install lowering springs ( H& R ) …don’t leave home without it.
I installed RimSkins when picking up my .1 GTS Targa at the factory. Easy to install. They've lasted 2,500 miles without issue (and speeds up to 125mph). Nearly invisible with the right color. Here's a link to the maker (no affiliation):
https://www.rimskins.com
You can read about it in the thread link found in my signature below.
