991 GT3, GT3RS, GT2RS and 911R 2012-2019
Exclusive Option Bolster Protector Install
Old 12-29-2022, 04:13 PM
Maxhouse97
Maxhouse97's Avatar
Reviving this thread as I have run into a couple of problems doing this install. Has anyone else experienced this?
- When trying to pull out the seat height adjustment switches, one of the switch surround covers broke, and the other came off, thereby not allowing me leverage to inch the switch out. My next thought was to use a set of needle nose pliers to pull it out - thoughts?
- When I pulled up the seat cushion on the divers side seat there west no issues. On the passenger side, I was surprised to find two plastic tabs that held the seat cushion down that I have now also broken, in addition the a metal clip. Anyone have this problem? I am wondering if I need to replace these (I assume that the Velcro will be enough to hold the seat cushion down, but realize that the plastic clips and metal clip were there for a reason).
It is winter time (although 50 degrees here today) so not sure if the cold had something to do with the difficulty here. Thanks.
Old 12-29-2022, 04:37 PM
Maxhouse97
Maxhouse97's Avatar
Quick Reply: Exclusive Option Bolster Protector Install
