Full Cage
Full Cage
Anyone know of a vendor with experience installing a full cage in a 991 GT3? I'm assuming there's not an "off the shelf" full cage at this point (only half cage behind seats)?
Thank you.
Thank you.
You don't get a cage for side protection unless you are going racing and putting nascar door bars in. Cages are for the most part roll over protection, and though this doesn't look like the stoutest example, it does look like it would help. We also can't see what is going on in the rear of the car. Unless you are going to pull the dash and cut/notch everything to get the A pillar bars to fit closely, this is about as good as you will get.
