Are Yellow Calipers Same as the Red Ones?
It doesn't sound like an easy process:
http://www.brembo.com/en/company/new...alipers-brembo
or is it just marketing bs?
If I have them painted will the colour hold same as OEM caliper's colour?
As others said, you will not be able to fit OEM yellow calipers to OEM steel rotors. It sounds like painting is what you need. There is heat resistant paint they use (was told before why it is better than powder coating but forgot), then a "PORSCHE" sticker that can handle the heat (sun coast has it, you have to dig for it), then all gets covered with heat resistant clear coat.
Wouldn't that sticker burn from the temperatures?
I am not. I can say that Suncoast definitely carried high temperature paint for the calipers as well as the sticker (can't find it now to save my life). I don't know if the clear coat would protect the sticker from burning (no oxygen) or if there is another method.
