Seat swap question
SJW, a Carin' kinda guy
Does anyone know if 991 (in particular a GT3) comes with the plugs for heated/ventilated seats if you order LWBs? How about if you order it with Sofas? Does 18 way v. 4 way matter? I know you would need to swap in the control panel for the heat/ventilated too so how about the switch connectors there?
I have delusions of having mismatched driver (LWB) and passenger 4 way heated/ventilated and want to see if that would work.
How about just dropping in non-heated ventilated 4 ways for an LWB seat?
Basically are 991 seats interchangeable and, if so, what to what and are the limitations or parameters? Someone must know.
TYIA
TYIA
TYIA
TYIA
No GT3 is offered with ventilated seats. At a recent custom tailoring meeting with Porsche Exclusive I asked if I could get ventilated seats and the answer was a flat "no" because it requires different wiring which is beyond the scope of Porsche Exclusive to change. So no, I don't think it would be possible (or straightforward anyway) to install a ventilated seat of any kind in a 991 GT3.
FWIW - Unless you're really in to the LWBs if you're going to go through the effort of swapping seats periodically I'd spec the car with 18-way and buy better race seats. The LWBs are awesome if they're your only seats but if you're going to the trouble, you can do much, much better aftermarket.
Anyone have any info on going from LWBS to 18-way? I am going to pull my LWBS out for 18-way and I have read that the wiring harness might need to be changed and I've read that they drop right in. Any insight would be appreciated.
Thanks!
Thanks!
