Dumb question I am afraid to ask...
For my 2015 GT3
I have a set of 19" BBS wheels at my tire machine and a set of 19" Ho Hos ready to lock and load. Precision inst torque wrench here Thursday. Somehow, do not think the other items I need come with the car, like central lock socket or cover wrench.
How screwed am I? Penetration in inches please. (I do have the special grease) May be some FedUPS shipping in my near future? Plan on running them this weekend and need to load the car into trailer sometime Thursday.
I believe the center lock socket comes with the car. You will need a serious breaker bar and either a friend to apply the front brakes or a "tool" to go between the front seat cushion and the brake pedal to stop the front wheels front rotating. Check to centerlock wheel change video.....GL..........in inches, not even getting the tip in....lol....
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Do you have PCCB's? If so 19's probably won't work. If steel you might be okay but still a pretty limited set of wheels that will clear the GT3 standard calipers. Assuming that is ok you need a breaker bar and torque wrench capable of 440 ft lbs. The center lock socket is under the hood front compartment in a pretty obvious enclosure. Assuming you've got the grease and a way to jack up each wheel you either need someone to step on the brake while the car is in the air or a pedal depressor.
SJW, a Carin' kinda guy
Dumb question, why do people use a breaker bar and not an impact wrench to remove? I totally get using a torque wrench to install, but getting it off why not use an impact gun? IR half inch are probably enough and IR 3/4in will rip off a rivet on the HMS Warspite.
GT3 player par excellence
^ the nut is alum. impact gun will kill the nut. if yo udont mind it chewed up , impact gun is good idea
For my 2015 GT3
Dark blue metallic GT3s matter.
Alan
Thanks everybody, only place I did not look was under there. Torque wrench will be here Thursday but wheels may be mounted and on the car by then, torque to spec on site if that happens.
IF you are changing wheels for the first time, give yourself plenty of extra time--this is not a 10 minute job like normal 5 lug wheels
also wear gloves and don't use a lot of the aluminum paste, as that silver paste is hard to get off skin, clothes, nut, rims etc
mind the directional arrows on the center lock nut also
at should be 2 seconds per minutes faster in R7's than Cup 2's
