Michelin Sport Cup 2 Falls of GT3RS at Track... What to do?
I think the car isn't over steered but the tire was "blown" or flattened before your turn in to left corner.
How hard is the breaking before this corner? I've heard that Trofeo R tires "spin" on the GT3 RS rims under the heavy breaking (No kidding!)
Your are lucky that this wasn't the fastest corner on the track!
Originally Posted by GrantG
Why are they so delicate? I thought they'd be tough since they're forged (unlike GT4's which are cast). Is there just too little material in the name of weight saving?
I use the TPMS to check while driving too. And it has been very accurate related to the gauge I use. So if someone's isn't accurate maybe they should be replaced?
The TPMS is probably +/- 1 PSI compared to a gauge because I know that there are certain values the TPMS never seems to show on my car... I have never seen 31 or 34 psi on the TPMS... Only 30/32 and 33/35
9/10 times this happens (leaky tire, dislodged wheel) you have / had a slightly bent rim already before and that leads to a wiggle in the tire bead. Streets of Willow is a crappy surface and those curbs and gators can yoink the tire right off the rims.
So, my theory is you have a bent rim, and if you don't get it replaced you will keep having tire issues especially on track.
If its my car I'm replacing that wheel and get 2 new rear tires.
Don't chance it.
Well I just looked at it and I can wiggle the valve stem and turn it by hand.
OMW to dealer, this should be interesting.
Wow thats crazy. Glad to see the car is still ok but let us know what happens at the dealer....
1.9 bar = 27.55722 psi
2.0 bar = 29.0076 psi
2.1 bar = 30.45798 psi
2.2 bar = 31.90836 psi
2.3 bar = 33.35874 psi
2.4 bar = 34.80912 psi
2.5 bar = 36.2595 psi
2.6 bar = 37.70988 psi
For when it measures 2.2 and 2.4 bar, respectively, it likely rounds up to 32 and 35 psi.
