Best new GT3 build for track use
#31
But that's my question, really. At high speed, I actually find the ability to modulate the PCCBs better than the Iron rotors that I had on my '16 Spyder, and a lot of the pro drivers have said they prefer the PCCBs on the track as well. I'm curious if there are people who have tracked both extensively found anything they didn't like about them, other than the cost.
#32
They're fantastic.
The fact that you get larger calipers to insert larger rotors is already a win, even if you track. Just remove the CCB, and replace w irons. On the 997's you get additional cooling duc work, bigger calipers, different hubs and "bigger" master cylinder- win /win/win / win over standard.
p.s.
You lads are missing some crucial information about the PCCB. The damping alone is a huge difference. The steering feel. I currently have the irons on my car, but my car came w/ pccb. Massive difference in steering and when the car is moving - the feedback the car gives.If i could afford $20k a year on brakes i would have PCCB.
#33
Don't know anyone who does more than four days a year who uses PCCBs on the track. Hold, I know one guy. He just killed a rear rotor and cost him $6k to fix.
#34
They're fantastic.
p.s.
p.s.
I can always throw steel rotors on.
All the best drivers I know love PCCB.
Then again, we're all trying to figure out how to cram 19" on the car so we can run faster tires....
#35
With the standard Red calipers, you can always use the stock 380's or add spacers and use the larger 410 rotors (including carbon-ceramic).
But with the PCCB Yellow calipers, you are stuck using the larger ones (which weigh a ton in iron)...
#36
#37
^ It's valid; the discussion is whether PCCBs are preferred, cost aside.
#38
Non-PCCBs also provide the ability to get smaller wheels (19s). PCCBs cost is too high. If they came down by 50%+ I might consider them.
#39
You can get 19"s that fit on PCCBs - HRE makes them and I think Forgeline might too. You should be able to run the new 488 Challenge slicks (ignoring the Porsche warranty issue) which are 275/675-19 fr and 315/705-19 rear. Both are approx 3% smaller diameter than the stock fitment for the RS, but I don't see that being an issue.
#40
#41
Base Car
Extended range fuel tank
LWB's
LWB's
#42
I love the PCCBs. The bite is great, the steering feel is great, no brake dust, don't have to change pads, no squeal - but this is a 3-4 day a year track car. For serious track work, I would go to iron.
#43
#44
...or somebody who will not track enough...or keep the car long enough...to go through a set of ceramics.
#45
Former Vendor
