Review: OEM Surface Transforms PCCB Rotor Kit for 991 GT3
#34
Hi guys, may I ask why nobody goes for PCCB disks refurbishment?
I found online a couple of companies which offers this kind of service, such as ReBrake
#36
Originally Posted by qbix
I don’t think you can refurbish PCCBs. They have different construction than ST (chopped fibers vs whole fibers). I would steer away from companies like ReBrake and all other names this company emerge from time to time.
could not agree more with this
#38
PCCB's can't be refurbished.
ST can and have been.
There are a few at Sebring that have gone through one refurb at least, maybe two.
But it takes about 20 track days before the fronts need it, so it takes time. I'm day 13.
It should take about 80-100 track days to finish off the fronts, seems like. I can see the first wear but not enough to ship them off the the UK yet. And here locally they have loaners for the couple of weeks that is takes to do. I will Post here to share that experience within a few more track weekends.
But it rains here non stop and next weekend I maybe in sfo for some canyon driving. As soon as my car is serviced I need to ship it somewhere dryer and cooler..
#39
I had an allocation for a .2 GT3RS and i'm wondering if could be worth to spec it PCCB's (in my heart i really want to). The car is going to be used by me and my brother and since we are planning to track it 10-12 times a year I'm consuming my self over this Hamlet-like question: PCCB or not PCCB..
I already spent hours reading older PCCB threads and I haven't found a post talking about those companies who claims to be able to refurbish OEM CCB disks. Since a owning period of a 3-4 of years could cost more than a couple of dozens K$ just in brake maintenance, I'm trying to figure out which could be the best performance\cost\self-rewarding solution among those that are already abundantly discussed.
Of course if Rebrake (or similar) can demonstrate to actually do an effective and reliable refurbishment, I think we can stop striving. That's why i'm trying to contact them, to ask if they already have done multiple Porsche OEM refurbishment and how they went.
#40
Just another thought as well for those deciding to order PCCB vs Iron on the initial configuration. If you swap either to the ST ceramics, is there any benefit to having the larger calipers from the PCCB's? Bigger brake pads? Sorry, I'm a novice to all things technical.
#41
I have done 5 days on the ST rotors and I love them. Performance matches the PCCBs but longer pad life. My pads show no significant wear, which is attributable to the lower operating temps. I'm looking forward to trying more aggressive pads, which these rotors allow you to do.
Thanks all for your feedback.
ST rotors are manufactured very different from the conventional carbon ceramic rotors. They are made out of layers upon layers of interwoven carbon cloth, instead of discontinuous bits of carbon. This basic difference (among several other variables) limits the carbon oxidation to the face of the ST rotors, which maintains the core strength of the rotor and allows it to be truly and safely refurbished throughout it's life.
Angiko if you are planning to track the car 10-12 times a year you should strongly consider saving the $9k option for the PCCBs and putting it towards the ST rotors. It is what all of the guys we work with have done on their builds. As explained above, when PCCB's reach their limit on carbon loss there is no saving them and you are out about $25k. If you save the $9k on the PCCB's and opt for the $13k ST rotors, the extra funds are offset at the first refurbishment. Instead of spending about $6000 per rotor to replace the PCCB's, you are spending about $600 per rotor to refurbish the ST's. These savings are compounded over time as you refurbish the ST rotors multiple times, versus tossing the PCCB rotors when they are done and having to spend $25k again and again. The cherry on top is that you can offset the initial costs of running ST rotors instead of PCCBs, as the factory cast iron rotors retail for about $4k a set and you can sell those if you wish. Therefore, your investment in the ST rotors would come out to be about the same as PCCBs and you have the tried and proven refurbishable ST carbon ceramic rotors that also have the additional benefits over PCCBs of better brake modulation/trailbraking, more aggressive pad options, longer pad life, cooler operating temperatures, etc. It is the logical choice. And if you want yellow calipers you can always have your red ones powdercoated yellow as we have done on several of our builds haha.
The red and yellow calipers from factory are the same calipers, the yellow are simply spaced out in the casting to accommodate the larger rotor diameter. When you swap to the ST rotors and space out the red calipers, you will simply use the same pad shape as the factory yellow calipers as they are the same caliper and now spaced out the same. For your reference the pad shape on the rear red and yellow calipers are the same from factory, it is just the front that differs slightly by fitting a wider pad to take advantage of the larger surface area of the ceramics.
#43
Guys,
To date the rotors and RSC1 pads have 1442 track miles and 12 track days.
The track days were at Laguna Seca, Thunderhill, and COTA.
The front rotors have no apparent visual wear. The rear rotors are showing slight grooving.
The pads are about half worn, with about 6 mm remaining. The pads wedge, and have been flipped once. I checked inner and outer pad wear.
I am going to change the pads soon as a precaution (heat transfer and resultant increase in rotor surface oxidation). The supplier, Autoquest, recommends running no less than 40 % total pad thickness.
Thanks for sharing such valuable info!
Btw, is there any weight differences between PCCB and CCB rotors?
#44
There is plenty on FerrariChat "experiences" of their customers.
#45
Negligible difference between the weights of the PCCB and ST rotors, you wouldn't be able to feel a difference. We have a new scale coming in the near future and will do a comparison, but the last time we did it the difference was in ounces : )
