Garage Saga Continues: Low-clearance experts needed
I assume moving is not an option? Car looks great.
I had the same problem when I moved into a new house a few years ago. I'd high center badly as soon as I got a couple of feet into the garage. My solution was to build a platform. I stacked multiple 2x10's, cut angles on the edges and staggered the top one to form a 'ramp'. As soon as the car would be close to high centering the front wheels would go up the ramp and eliminate the issue. I put cross braces in between them and then covered it with plywood. I then had a platform that was 6" high or so. It also served the dual purpose of making working on the rear of the car very easy- oil changes, for example. PM if you'd like more details. It took 1/2 a day and probably $400 of materials.
Alexio,
I'm no engineer, so no help on your ongoing garage saga, but seriously congrats on your Spyder, it is gorgeous car!
Also, big congratulations on getting engaged, I feel like we watched some of that unfold on the GT3 threads in 2013-14! Speaking of which what does your finance think of your the LWBs in your car?
Finally, you have to share with us about the very special P-car coming in 2017-
Did you get a .2GT3 allocation.......?
Congrats on the beautiful Spyder -- stunning color combo!
In fact, imagine a long wedge shaped ramp on each side; taller at the front (say 3 or 4") and thin and tapered at the entrance. You could just drive right in and never have a break-over to deal with. The car would be parked a bit ***-down but compared to most SF hills that would be nothing! I'll bet Raceramps could build you something that would work.
Perhaps another option is to bring in a company that polishes concrete and have them 'flatten' (polish off) the high point between the ramp into the garage and the garage floor. It looks like you only need a small change to clear.
This way, you'd have a permanent solution and avoid the need for ramps.
Another idea if you can/allowed, is to find out all your angles as many have suggested with boards acting like ramps then pouring concrete to give you a permanent fix, assuming you're really planning on remaining there for quite some time.
one rule: NO, IT IS NOT POSSIBLE TO PERMANENTLY ALTER THE CURVE (AKA MY DRIVEWAY) AS IT BELONGS TO THE CITY.. i need a temporary commercial solution which i can install when coming in and out on weekends, and then put back in the garage.
Have 6 guys lean on a shovel so it looks legit.
Ask for forgiveness not permission or pay the fine.
