RS Steering Wheel in the GT3
Porsche has gotten very protective of adding products after a build. I think you can swap it out but PCNA just won't allow a reflash for it to function. They seem to be doing this more and more to give more weight to what comes from the factory. It's the same with LED headlights etc.
The airbag module covers are different and the center hub w/ cover contains the airbag and horn which clearly look very different between the two wheels. I believe the $2870 from Suncoast includes the center section w/ airbag. Not sure why the steering wheel wouldn't be plug and play with the GT3. The software is in the transmission not the paddles, so unless the connectors were different (which they may be) the RS wheel should just plug into the GT3 steering column.
Makes sense. Just because something can be done doesn't mean Porsche will let it be done.
The different steering wheel and air bag may technically require recertification so the group buy would have to include the cost of a gt3 and a crash test. This makes the rs and even better value ; )
