991 GT3, GT3RS, GT2RS and 911R 2012-2019
Cantrell installs my half cage with sub bars
Old 05-02-2015, 11:27 AM
montoya
montoya's Avatar
Default Cantrell installs my half cage with sub bars
Thought you guys would like to see the install and how the sub bar works out.
Shop was full of cars from their recent tour of tracks in California and COTA. Two McLarens in addition to multiple Porsche's and other cars.
My Cage before install- really nice mat finish.
Here they are the sub bars- just the third set they have made so far.
Justin hard at work..
Old 05-02-2015, 11:28 AM
montoya
montoya's Avatar
Mounting point on the side of the seat
Very tight!
The sub bar needs to clear various items under the seat and still allow full range of motion for the height adjustment. Very clever engineering!
Done! Passenger side harness, finally!
Nice day at Cantrell- thanks guys! (my buddy's original owner E30 M3 in the foreground)
Old 05-02-2015, 11:36 AM
awew911
awew911's Avatar
Nice. Doing mine today across the country.
Old 05-02-2015, 11:54 AM
Alan C.
Alan C.'s Avatar
Received 1,061 Likes on 547 Posts
Nice, clean install.
Old 05-02-2015, 12:01 PM
montoya
montoya's Avatar
Oh, by the way you can remove the Schroth buckle easily and it makes it possible to stuff your center belts under the seat without removing the seat cushion from the front edge.
The buckle has a hole you press the release in with a narrow punch and you can then remove it.
Old 05-02-2015, 12:04 PM
montoya
montoya's Avatar
Saw your work so far- you are on the home stretch! Good job! Are the seats hard to remove? Reason I ask, is that Justin suggested that once the plates are in, removing the cage is not hard if you want the rear access between track days.
Old 05-02-2015, 12:23 PM
audipwr1
audipwr1's Avatar
Same connector and looks like same rail mounts for 996 and 997
Old 05-02-2015, 01:05 PM
neuroguru
neuroguru's Avatar
Can you send a link to the punch that you used to release the buckle from the sub belt? That would be nice to put on the track tool thread.
Old 05-02-2015, 01:41 PM
montoya
montoya's Avatar
I wish I knew, it's a hand me down. I would say that a small fine phillips screw driver of sufficient length should work just a well. You are depressing the latch, even though the hole is small, the latch is fairly large so you just need something stout enough to press it down to release the buckle.
Old 05-02-2015, 01:46 PM
Mech33
Mech33's Avatar
Could you post a pic of what you're talking about? Schroth told me they could modify the buckles so that they stayed attached to a lap belt instead of the sub belt to help with the 991 issue of them not tucking away easily, but they didn't mention that you could just use a small tool to temporarily remove the buckle entirely! Does the sub belt buckle just click back in afterward, and then needs the tool again if you want to remove it? (fully reversible)
Old 05-02-2015, 02:05 PM
Spyerx
Spyerx's Avatar
Received 1,843 Likes on 1,123 Posts
That's a trick setup. Nice job by Cantrell.
Old 05-02-2015, 02:10 PM
montoya
montoya's Avatar
Yes it's fully reversible and it's just a hidden latch.
I will try to take some pictures today.
Old 05-02-2015, 02:18 PM
SmokinGTS
SmokinGTS's Avatar
Justin is a real pro at installing the bars. I wish I had a day with him before tackling mine, It would have cut my install time in half.
Old 05-02-2015, 02:33 PM
Mech33
Mech33's Avatar
Yes, hats off to them for doing this the right way.
Old 05-02-2015, 03:18 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,853 Likes on 2,395 Posts
justin is a master
I
bought his track
car it's done prettier than garage wueen
Quick Reply: Cantrell installs my half cage with sub bars
