PDK Observations
Paddles mostly, and grab neutral when approaching stop like I would in manual car, unless on track. No need to downshift on the street for a stop sign or light. The gearbox just auto selects lower gears as you slow, even in manual mode, if you pick neutral with both paddles.
No clunks as you come to a stop. I just don't like the feel of any clunking or grabbing in the driveline as you slow gently, as driveline shock is never a good thing -- only be used when trying to derive performance
After about 3k miles I have now come to appreciate and enjoy the clunky and jerky-ness of the PDK-S at low speeds around town.
It's significantly reduced my need for Ex-Lax. Which I am ok with.
Paddles mostly, and grab neutral when approaching stop like I would in manual car, unless on track. No need to downshift on the street for a stop sign or light. The gearbox just auto selects lower gears as you slow, even in manual mode, if you pick neutral with both paddles. No clunks as you come to a stop. I just don't like the feel of any clunking or grabbing in the driveline as you slow gently, as driveline shock is never a good thing -- only be used when trying to derive performance
To the OP, I'm in manual mode 100% of the time. Except for my first night in the car. Didn't know any better.
Auto mode shifts too early- it wants 6th/7th. I nearly always drive in manual and shift with the paddles. Much more fun. When slowing to a light or stop sign let it do the downshifting. Manual downshifting when slowing can be a little clunky. On a long highway trip I do use auto. On a 2 lane road and needing to pass another vehicle just nail the throttle and auto will select the right gear and bang gone.
this has been discussed before though.
Auto
OK, I have been taken to task on this by a number of Porsche friends (not 991 GT3 owners) but auto S mode on track - only two days before winter cut this off 2014 - is amazing. I'll be evaluating this quite a bit in upcoming months but between the paddles and auto hard to decide....one hint is the corner workers.... when really getting it going they smile (and at lunch chat) about the fantastic sounds and downshifts and putting down the power out of the corner....well ...auto or whatever...this car can really impress.
Is one a lesser driver in PDK-S....Hmm...more focus on throttle inputs, car dynamics, general track awareness....I think not. Probably faster, safer and more fun all around even.
Will update comments in a few months! Enjoy......
Around town forget it never use auto, worse than my Subaru.
PR
PR
i hate the auto mode that shifts to 5th before i cross an intersection. Sport holds the gear too long for street driving so i am driving it like a 2 pedal manual. Will try sport at the track - i suspect there, the programming will be fine. I also dont like the clunkiness when rolling to a stop but you dont stop - the famous NJ rolling stop . will try the neutral thing and see if it helps
When you do the neutral with the paddles, do you hold them in just for a sec or two or do you have to hold them in until you come to a complete stop?
You're in neutral as long as both paddles are pulled in. Back in gear when released. I usually keep them pulled in until I come to a complete stop.
I pull the paddles to put the car in neutral when approaching speed bumps with nose lift activated. Much smoother IMO. I have a series of 4-5 to negotiate at one of my places in the burbs.
besides more fun to downshift
