Harnesses installation questions
Guys,
Need your help. Posted this on Pistonheads too but really could use your help. I had the harnesses installed by the dealer today. I have a bit of an issue as when the seat is fully pushed back it looks ok and the harness is wearable.
BUT if I push the seat forward. Because that's something you also occasionally do with a seat which allows you to do that and you are a short Italian fella like me... We have the CASTRATION mode.
I assume this is due to the straps BELOW the seat being too short. I cannot think that it can be so stupidly designed. So can somebody with experience tell me if they can be adjusted? I could feel the mounting below the seat but couldn't really see how you would do it. HELP!
I attache the 2 pictures.. one with enough strap available to comfortably wear the harness (seat fully pushed back), the other where it's physically impossible to put it on (seat closer to the steering wheel).
The cam lock should be adjusted to your driving position. All the way back and you will have excess belt. All the way forward and the belt will be shorter. It is only going to be correct in one position on the slider. What did they anchor the sub straps too beneath the seat?
Looks like the sub strap is attached to the floor and not the bottom of the seat, unless something else is amiss. If it is properly attached to the bottom of the seat, the length of the strap should not change with seat position. Can you look under the seat while you move it and see where is it attached?
Indeed I would hope there is an adjustment possible, I couldn't immediately see where or how yesterday evening but will give the Opc a call. Some say the cushion is also attached with Velcro so maybe accessible from there. I haven't tried.
Strange thing is OPC didn't even ask how I wanted it so pretty obvious must be the second car they do and had no idea. Also indeed seems strange not attached to the seat like in the old gt3 such as the 996 which would make it much more convenient and indeed work with movement of seat.
The sub bar mount is convienient. Probably not as good from a load point of view when compared to mounting to the floor. I've had 7 point mounts in my past cars. The center strap goes straight down and the two side straps are mounted to the floor about 8 - 10" apart and roughly under my hip joints.
The inside of your thighs take the sub load in a crash and the vertical strap keeps you in the seat in a roll over.
I purchased the new GMG sub strap mount, but haven't received it yet. I'll let you know how it goes. Seems to be only 0.4" off the ground and have several mounting points for comfort.
Slightly off topic but not so much... I've been adjusting my belt positions and have a question on the anti-sub belt.
Does anyone have a picture of the PROPER location of the CAM lock and height of the sub belt relative to the side and shoulder belts? Ideally with a driver in the seat? Mine was too high, I've lowered it. want to see if it's right, I think it is based on the angles and locate now.
The Schroth guide and searching hasn't resulted in much.
