991 GT3, GT3RS, GT2RS and 911R 2012-2019
991 GT3 CCB vs Steel - weight differential???
Old 02-26-2015, 05:09 PM
GrantG
GrantG's Avatar
Received 4,721 Likes on 2,691 Posts
Check post 49 on page 4 of the following thread:
https://rennlist.com/forums/showthre...eferrerid=8132
And post 50 has a weight reduction chart for carbon vs iron
Old 02-26-2015, 05:10 PM
orthojoe
orthojoe's Avatar
If you're a PCA member, there's an article about the realities of PCCB in this issue:
https://www.pca.org/panorama/edition...-november-2014
Old 02-26-2015, 05:13 PM
orthojoe
orthojoe's Avatar
Context error.
Read post #79
https://rennlist.com/forums/991/8460...l#post12071652
Old 02-26-2015, 05:16 PM
Mike in CA
Mike in CA's Avatar
Originally Posted by golfnutintib
mike - 10 lb PER ROTOR? must be even greater in the rear...
Ok found it....post #1.....yes, almost 10 pounds per rotor. The numbers are below:
Front:
RacingBrake replacement: 15 lbs
OE's pccb = 14.8 lbs;
Iron Rotor: 24 lbs (Center Lock hub)
Iron Rotor: 27.6 lbs (5-Lug hub)
Rear:
RacingBrake replacement: 14.3lbs
OE's pccb = 13.3 lbs;
Iron Rotor: 24 lbs (5-Lug hub)
https://rennlist.com/forums/991-gt3/...ally-here.html
Edit: guess some other folks beat me to it....
BTW, I'm not getting into the suitability discussion again, but you asked for a weight comparison, so there it is.....
Old 02-26-2015, 05:19 PM
GrantG
GrantG's Avatar
Originally Posted by orthojoe
I agree that it's confusing. I also sent a PM to Racingbrake for more info a couple days ago, but haven't received a reply.
Old 02-26-2015, 05:58 PM
GrantG
GrantG's Avatar
So, just to follow-up and further muddy the water...
I just telephoned Racingbrake and they confirmed that the CCM rotors made by Surface Transform in the UK (and sold by Racingbrake) can definitely be refurbished. But he also said he thought there was a company that can refurbish OEM PCCB rotors also, though he did not have the name of the company nor definite confirmation of that fact.
Old 02-26-2015, 09:55 PM
brass4321
brass4321's Avatar
This was covered in another thread, one started by Racing Brake about their PCCB or iron replacement kits. It's a Slovenian company that claims to apply a new, stronger laminate to the PCCB.
Old 02-26-2015, 10:10 PM
GrantG
GrantG's Avatar
Thanks!
Old 02-26-2015, 10:13 PM
GrantG
GrantG's Avatar
Google search turned this up - try each tab for info, prices, etc.:
http://www.ceramicdiscrefurbishment.com/faq
Old 02-27-2015, 12:57 AM
orthojoe
orthojoe's Avatar
Google search turned this up - try each tab for info, prices, etc.: http://www.ceramicdiscrefurbishment.com/faq
Interesting. Who will be the first to try it?
Just received a reply from RB that they can only refurbish ST discs. NOT OEM pccb
Old 02-27-2015, 02:05 AM
golfnutintib
golfnutintib's Avatar
RB not being able to refurbish OEM CCB's is a totally expected response.
Who's worn down their CCB rotors enough to try the SICOM Slovenian thing? Somebody needs to take one for the team! I'll believe it when I see it -- LOL
Quick Reply: 991 GT3 CCB vs Steel - weight differential???
