Has anyone replaced their front spoiler yet?
#31
I have a new spoiler sitting in the garage ready to replace this weekend if it warms up a bit. Kissed a curb when I wasn't paying attention. The spoiler and Xpel Ultimate absorbed the damage. I probably shouldn't bother replacing it yet. You can hardly notice the scrapes, but I know they are there. When I hit the curb it it felt like a telephone pole when through the front grill. All I can say is thank goodness for Xpel. I would have done visible damage to the bumper if I didn't have it installed. There was a little rash on it so I peeled it back the bumper was fine. The stuff is really thick. Need to have Derek at Atlanta Protective Films touchup the bumper for me. I'll let you know how the spoiler install goes when I get to it.
#32
#33
#34
I've replaced mine several times on my 2008 GT3. I always bought OEM until this last time. I bought an aftermarket product available on Amazon and elsewhere. It's made in Taiwan. Cost $201.00 --about seventy dollars cheaper than OEM. It doesn't fit. Comparison with the OEM product showed the aftermarket one doesn't have sufficient clearance just above the lip's air cut-outs. It couldn't be pressed into place on the bumper. I suppose I could have made it fit by trimming material off my front bumper with a snips, but I'm not going to do that. Also, the product had no provision for the fasteners at each end. So heads up!
#35
Sunset Porsche (not Suncoast) has it for about $160, plus about $60 for shipping.
#37
Yeah, it depends on the track. My home track is Texas World Speedway. When you go off there, if you're lucky, you just end up in the grass. I've never lost my lip there, but the front brake air scoops frequently tear off. The same holds true for the GT2 rear brake air scoops (if you've got them) which is why I don't use them.
Thanks for the tip about Sunset.
#39
i finally replaced my spoiler today. Pretty easy, although getting the old one off takes a little work. The spoiler is attached by a single screw on each end and several tabs that lock into slots in the front bumper. In addition to the spoiler screws I removed the two screws in each wheel well closest to the spoiler. I thought removing these would help loosen the spoiler but I'm not sure they did anything. Once the spoiler screws were removed it took a little force to get the old spoiler out. The tabs don't release easily. I pulled some free with a good tug. For others I gently slid an old screwdriver above the tabs to release them from the slots in the bumper. I was very careful to avoid contact with the painted edge of the bumper. I don't know if this is the correct method for releasing the tabs so I am not advocating doing it this way, but it worked for me. It may be worth checking with a service advisor or tech to see if there is a procedure for releasing the tabs. Once the old spoiler was removed I installed the new one by attaching it on the right side of the bumper and snapping the tabs into place as I worked my way around to the left side. I then replaced the screws and that was it. The whole thing probably took 30 minutes, but that is because I was taking my time. It can probably be done in half that. Below are some pictures I took along the way. Hope this is helpful!
The screw on top of the black tab holds the spoiler to the vehicle.
A sample of the tabs that hold the spoiler to the bumper.
Pulling the spoiler free from the bumper.
Spoiler coming free.
Using screwdriver to release tabs.
No spoiler.
Shiny new spoiler!
No spoiler.
Shiny new spoiler!
#40
No spoiler.
Shiny new spoiler!
No spoiler.
Shiny new spoiler!
#41
I pulled each end out then worked the tabs. You need to work them a bit. If you remove a couple of screws from the inner fender I think you can see behind the spoiler and possibly release the first tab with a screwdriver. If not, twist and pull. It will let go. Good luck!
#42
No spoiler.
Shiny new spoiler!
No spoiler.
Shiny new spoiler!
thnx for the write up and images Lodi
#43
Ordered my front lip from Suncoast during thanksgiving, $179, free shipping. Took less than 5 minutes to replace. After removing the 2 screws with a torx wrench, pulled hard and the front splitter came off. I would have never known to pull so hard if I didn't read this post before. You do need to push hard and slap the corner areas so the tabs go in properly.
#45
[QUOTE=SMGT3;12823722]Ordered my front lip from Suncoast during thanksgiving, $179, free shipping. [QUOTE]
I took advantage of the same deal and now that it's here I've just wrapped it up and will leave the old one on until it's absolutely shot I think.
