First LWB with harness installed driver and passenger
The pass through hole in the driver's shell is just a simple cutout. There is no hole in the bottom of the passenger shell.
^^^^This is depressing. I wonder how to get around the air bag seat sensor ? Cutting a hole is no big deal. Perhaps a custom car upolstery shop can work with the seat cushion. On another note, I wonder if the RS will have LWB's standard or as an option ? If the latter I would order sofa's and buy aftermarket buckets that do work with harnesses.
With the Velcro surround loosened, the seat cushion is still hooked down, and I can't tell how to get it off all of the way. You can feel the flat sensor beneath the cushion, but it doesn't seem to extend beyond the seam that you can see in the cushion pictures.
The top picture that looks smooth is from the passenger seat. The yellow plug is visible from the footwell. The area of carbon fiber corresponds to where the pass through is on the driver's seat. The lower picture with the hole is taken from below the driver's seat. The hole appears to have been cut through a single layer of material, and has unfinished edges. The bottom of the cushion, and its pass through is seen through the seat pan hole.
Ok, bummer and thx!
Hey guys any progress? Anymore info on the passenger side?
My car w/ LWB is at GMG getting cage, harnesses, tint & clear bra completed before I take delivery. Jerry @GMG is looking into solutions but it sounds like I'll be doing a 6pt on the driver side and a 4pt on the passenger. Seats should be coming out in the next few days for the install.
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,800 Likes
http://www.ogracing.com/blog/2013/02...or%206%20point
Really sucks that Porsche screwed this up ...
Most clubs won't allow a 4-pt harness, and it's generally not recommended from a safety standpoint:
^Agreed. If you don't modify the seat for the 6 pt belts then most organizations will mandate that driver and passenger wear the same belts- the standard 3 pt belts.
Really hoping that someone tries to make the 6 pt work on the passenger side- I'm still waiting for my car...
