Real life pic of why you need front lift!
True dat...the manual says that the lift "cannot be maintained in the upper position over an extended period without active replenishing of the pressure accumulator or engine operation" so you shouldn't park over the top of stuff for long periods of time.
That said, as long as the lift is good working order, parking somewhere for a couple of hours isn't going to be a problem. I've forgotten to lower my car in the garage a few times and come out a day later to find it still proud and erect.
As long as there are people who want to justify their decision to add lift or delete lift there will be a dispute as to whether the lift is needed or not.
There will be people who have the lift and forget to use it and get a crunch and there are people who don't have the lift and get a crunch. Whatever the case it's pretty much a foregone conclusion with a car this low that there will be a crunch with or without a lift.
Dan (has a lift ordered and hopes to have fewer crunches than the guy who left if off)
Apologies if these are redundant for some, but others here may have not seen these pics that I posted a couple of months ago of my own driveway. Not all that steep just looking at it, but without the lift a LOT of jockeying is required to get up with only minor scraping. With the lift, no contact, no problem....the debate DOES live on.
It's not the 100 times that you don't need the lift that makes the case, it's the one time that you really, really do!
With your driveway you obviously need the lift. My driveway actually looks much steeper than yours, yet I get no scraping with the GT3. My 2007 Corvette would scrape occasionally if I did not take the right angle. With the GT3, I can go straight up with no weird angle issues.
Nope, the lift is not engaged. With the lift engaged it's close but there is no issue with clearance.
When I'm going up my right front wheel lifts off the ground due to the stiffness of the chassis and the angle of pavement plus the dip at the bottom of the driveway (hard to visualize from in the pic). The unloading of the right front suspension is why there appears to be excessive clearance over the right front wheel and might make it look like the lift is engaged.
I support you Foweiee... I travel to Europe 3-4 times a year... Roads there are not like they are here.. Cobblestone is not your friend and parking is like a privilege..... I live in Central Florida where the roads are pretty good and I can't say how many times I have used the lift. Others prefer to scrape or squint and grit their teeth?? I prefer to lift..
My first thought.
Thanks goodness. And thanks for posting the pic -- I had not seen it the first time around. I never thought about not getting the lift, but that photo really drives the point home as I will need to tackle inclines that are at least that steep.
the front is made to be hit.
for steep inclines.. the 30* angle rule always works... one wheel touches and lifts the front and by the time the rear would be in danger the rear wheel lifts for the rear... and you're golden.. having driven insanely lowered vehicles over the years.. it's an end all be all solution for low front ends..
