991 GT3, GT3RS, GT2RS and 911R 2012-2019
Extended range fuel tank
Old 09-18-2014, 08:09 AM
kneman1
kneman1's Avatar
Default Extended range fuel tank
Hey guys. I locked my build in Sept 3 and I tried to change my build to add extended range fuel tank. They refused. 2 questions.
1. Is there anyone to contact that can maybe help dealer telling me they called and emailed they were denied. Anyone here can make a contact for me ?
2. How big of deal is it not to have that feature. I didn't realize the gas mileage was 25 percent less than a turbo until recently. I am using as DD and would love to have the extended range.
Old 09-18-2014, 08:18 AM
sccchiii
sccchiii's Avatar
You say you "locked" your order on sept 3rd, when does your build sheet say the production date is for your car?
Old 09-18-2014, 08:19 AM
kneman1
kneman1's Avatar
Good question I have no idea.
Old 09-18-2014, 08:20 AM
kneman1
kneman1's Avatar
where would I find that
Old 09-18-2014, 08:24 AM
jlanka
jlanka's Avatar
It might not be listed yet. Best bet is to check with the dealer to see what is in the computer.
Old 09-18-2014, 08:25 AM
kneman1
kneman1's Avatar
Build sheet says V210 freeze point reached
Old 09-18-2014, 08:29 AM
sccchiii
sccchiii's Avatar
Should be 1 of the pages of your order summary sheet that also contains commission number supplied to you by dealer. Depending on when your car starts production you should have time to change your order before it truly locks just before production, ironically enough I had dealer add extended range fuel tank to mine because I missed it when we built my car. First thing I would do is ask your dealer for build sheet with commission number on it and eta dates of progress of build. If they continue to give run around reach out to Porsche and see if they can nudge dealer to go in system and make this simple change. The only thing that would prevent change is you are past the point of changes to your build because order is truly locked by Porsche for final review and production .
sccchiii
sccchiii's Avatar
You are past point of making changes
Old 09-18-2014, 08:35 AM
kneman1
kneman1's Avatar
Is there anyone I can email or call?
Old 09-18-2014, 08:43 AM
JCL59
JCL59's Avatar
The extended range tank will make a difference on track or on long trips, Otherwise not a deal breaker...
My RS burns through a 1/2 tank in a 25min session so the extended tank might get you though 2 sessions with some to spare to
Old 09-18-2014, 08:44 AM
sccchiii
sccchiii's Avatar
I don't believe there is anything that can be done maybe others can chime in? I suggest you plead with dealer to call there Porsche factory rep and also call Porsche customer service on website and explain situation
Old 09-18-2014, 08:45 AM
sgroer
sgroer's Avatar
Received 1,013 Likes on 280 Posts
Call porsche NA headquarters and see what can be done. A simple change this late in the game is rare but I don't believe it is unprecedented, especially given its a 0 cost option.
carcommander
carcommander's Avatar
I wouldn't sweat it. You can always add it later.
Old 09-18-2014, 10:12 AM
brass4321
brass4321's Avatar
deleted
Old 09-18-2014, 10:14 AM
kneman1
kneman1's Avatar
Anyone have the contact for Porsche NA headquarters
Quick Reply: Extended range fuel tank
