Rear Wheel Steering Durability - Track Days
I disagree, I see that little rubber cover over an electric thingy and than see how we melted and broke caliper pistons, rotors, broke sway bar mounts, etc. etc
Shops start messing with setup, control arms, bushings maybe. I'd leave this one bone stock!!
Could work, I'd like to see it work at Sebring for a while before I'm sold. Just like the PDK, works in most places, but it has not been trouble free and has overheated..
GM had this on Suburbans years ago. Made the really easy to turn around without need of a football field.
They DON'T offer it anymore. (Hint)
I came across these pics from the 991 turbo and turbo S technical service information brochure (SIT) regarding RWS. What I found interesting was according to the SIT, the virtual wheelbase will change by +500mm for high speeds turns (lengthening, red lines in pic) and -250mm for low speeds turns (shortening, blue lines in pic).
It appears that the virtual center of mass at the high speed turns may also create closer to mid-engine-like rotational dynamics. Coupled with the more direct center steering (Porsche claims the steering ratio on the front axle is 10% more direct center when compared to 991 Carreras), which the RWS can handle due to the lengthened virtual wheelbase, resulting in a more responsive steering/handling/agility of the vehicle.
I suspect the RWS on the GT3 when compared to the RWS on the turbo/turbo S is at least equivalent to or better than in terms of rotational dynamics.
